63 arm rest - NCRS Discussion Boards
63 arm rest
+ More Options
Posts
  • Perry M.
    • January 1, 1977
    • 325
    63 arm rest
    Something about my center arm rest in my 63 SWC has always bugged me. The armrest was off center to the driver's side of the transmissin hump. I always figured I would lossen the bolts/screws and adjust it to the center but when I tried, I found out that the hole for the pin on the armrest was drilled offset. No adjustment could be made. Is this the way they all are?
    • 6948
    Re: 63 arm rest
    Perry, Are you talking about the dowel on the rest its self? or where the bolt in front goes? I know that mine is dead center. so if the problem is metal base then they do repro that part.
    • Perry M.
      • January 1, 1977
      • 325
      Re: 63 arm rest
      The dowel at the back is in the center of the armrest but the hole that it goes into is not centered over the transmission/driveshat hump.
        • 6948
        Re: 63 arm rest
        Perry can you drill another hole next to it? since the carpet covers the hole it should not be seen. really not much else you can do. that plate behind seat and arm rest is spot welded. or the another possiblity is to relocate the pin. maybe remove dowel and relocate the dowel, just use a 3/16 sloted screw and a nut to lock in place.
        • Perry M.
          • January 1, 1977
          • 325
          Re: 63 arm rest
          I can drill a new hole to center the dowel over the hump but I was just curious if this is the way they all are or is mine unique.
            Re: 63 arm rest
            Perry -
            A previous owner may have replaced the luggage stop panel (which has the dowel hole in it) to cure a floor sag problem and didn't center it correctly when re-riveting it.
