Help with 327 engine suffix code SH - NCRS Discussion Boards
  • Jerry W.
    • January 27, 2009
    • 588
    I've tried and tried to find this Tonawanda engine suffix code SH without success...Engine was in 62 vette when purchased in 70's
    casting 3782870 ( small letters ) .....cast date K6 62 ( two digit year )
    Just curious before i get rid of it.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Help with 327 engine suffix code SH
    Jerry,
    My book of engine info (Lime Book by Ed McComas) does not list any SH suffix for any GM engines both Tonawanda or Flint.
    • Jerry W.
      • January 27, 2009
      • 588
      Bruce....Exactly what i found...I did find same question about the SH code on one of the chevy forums with no answer there either.
      You can see that the pad includes a rebuild stamp by someone....RC440
        It's probably a marine or industrial/agricultural application.
        • Patrick B.
          • August 31, 1985
          • 2009
          It appears to have a Kansas City VIN number on it. Typically 327-300 and 340 pass car engines got this kind of VIN marking in 62.
          • Ray G.
            • May 31, 1986
            • 1189
            RPO FY CID Appl VIN HP BBLS Body/Comments
            FG 1955 265 Powerglide 195 4 Vette
            GR 1955 265 m/t, 3 spd 195 4 Vette
            FG 1956 265 Powerglide 225 4 Vette
            GR 1956 265 m/t, 3 spd 225 8 Vette
            GV 1956 265 Powerglide 210 4 Vette
            EF 1957 283 m/t, 3 spd 220 4 Vette
            EG 1957 265 2 4b,hi-lift cam,m/t - 270 8 Vette
            EH 1957 265 twin 4 barrel, m/t - 245 8 Vette
            EL 1957 283 m/t, 3 sp, h/I cam 283 FI Vette
            EM 1957 283 m/t, 3 spd 250 FI Vette
            FG 1957 283 glide, 2 4b, a/t 245 8 Vette
            FH 1957 283 Powerglide 220 4 Vette
            FK 1957 265 Powerglide - FI Vette
            E 1957 283 manual trans. - 185 2 Vette/truck
            CO 1958 283 m/t, 3 spd 230 4 Vette
            CR 1958 283 m/t, 3 spd 250 FI Vette
            CS 1958 283 m/t, 3sp, hi lift cam - 290 FI Vette
            CT 1958 283 m/t, 3 spd 245 8 Vette
            CU 1958 283 m/t, 3sp, hi lift cam - 270 8 Vette
            DG 1958 283 Powerglide. 230 4 Vette
            DH 1958 283 Powerglide 250 FI Vette
            DJ 1958 283 Powerglide - 245 8 Vette
            QB 1962 327 - - 8 Vette
            RC 1962 327 m/t 250 4 Vette
            RD 1962 327 m/t, high perf. 300 4 Vette
            RE 1962 327 m/t, spec. hi perf. 340 4 Vette
            RF 1962 327 manual trans. 360 FI Vette
            SC 1962 327 Powerglide - 250 4 Vette
            SD 1962 327 glide, s hi perf. 350 4 Vette
            RP 1964 327 m/t, a/c 250 4 Vette
            RQ 1964 327 m/t a/c, hi perf 300 4 Vette
            RR 1964 327 m/t, a/c, s hi perf 365 4 Vette
            RT 1964 327 m/t, t/ign. 365 4 Vette
            RU 1964 327 m/t, a/c, trans ign 365 4 Vette
            RX 1964 327 m/t, trans ign 375 FI Vette
            SK 1964 327 Powerglide, a/c - 250 4 Vette
            SL 1964 327 glide, a/c, hi perf. - 300 4 Vette
            HE 1965 327 m/t 300 4 Vette
            HF 1965 327 h/p 300 4 Vette
            HG 1965 327 fuel inject, m/t 375 FI Vette
            HH 1965 327 s h/p, m/t 365 4 Vette
            HI 1965 327 a/c, m/t 250 4 Vette
            HJ 1965 327 h/p, a/c, m/t 300 4 Vette
            HK 1965 327 s h/p, a/c, m/t 365 4 Vette
            HL 1965 327 trans ign, m/t 365 4 Vette
            HN 1965 327 t/ign., m/t 375 FI Vette
            HO 1965 327 Powerglide 300 4 Vette
            HP 1965 327 Powerglide, h/p 300 4 Vette
            HQ 1965 327 Powerglide, a/c 250 4 Vette
            HR 1965 327 Pwrglide, h/p, a/c 300 4 Vette
            HT 1965 327 s h/p, hyd lift, m/t 350 4 Vette
            HU 1965 327 h/p, hylft, a/c, m/t 350 4 Vette
            HV 1965 327 h/p, hyd lif, t/ig, m/t 350 4 Vette
            HW 1965 327 s/hp, hl, ti, ac, m/t 350 4 Vette
            HM 1965 327 a/c, trans ign, m/t 365 4 Vette/Chevy II
            IF 1965 396 Mt 425 Vette
            HD 1966 327 a/c, spec high perf. 350 4 Vette
            HH 1966 327 air inj. reactor 300 4 Vette
            HT 1966 327 s h/p, hyd lift, m/t 350 4 Vette
            KH 1966 327 s h/p, A.I.R., a/c 350 4 Vette
            IR 1966 427 PG AR 390 Vette
            IK 1966 427 Mt SHP 425 Vette
            IP 1966 427 Mt SHP 425 Vette
            IL 1966 427 Mt 390 Vette
            IM 1966 427 Mt 390 Vette
            IQ 1966 427 PG 390 Vette
            HT 1967 327 s h/p, hyd lift, m/t 350 4 Vette
            IT 1967 427 Mt SHP 435 Vette
            IU 1967 427 Mt SHP 435 Vette
            JA 1967 427 Mt SHP 435 Vette
            JE 1967 427 Mt SHP 435 Vette
            JH 1967 427 Mt SHP 435 Vette
            IL 1967 427 Mt 390 Vette
            IM 1967 427 Mt 390 Vette
            IQ 1967 427 PG 390 Vette
            IR 1967 427 PG 390 Vette
            JC 1967 427 Mt 400 Vette
            JD 1967 427 PG 400 Vette
            JF 1967 427 Mt 400 Vette
            JG 1967 427 PG 400 Vette
            IM 1968 427 Mt HP 400 Vette
            IO 1968 427 TH HP 400 Vette
            IR 1968 427 Mt SHP 435 Vette
            IT 1968 427 Mt SHP 435 Vette
            IU 1968 427 Mt SHP 435 Vette
            IL 1968 427 Mt 390 Vette
            IQ 1968 427 TH 390 Vette
            HW 1969 350 hi perf eng, m/t 350 4 Vette
            HX 1969 350 high perf, a/c, m/t 350 4 Vette
            HY 1969 350 m/t 4 spd 300 4 Vette
            HZ 1969 350 tur 400 300 4 Vette
            LP 1969 427 Mt alum hd 435 Vette
            LU 1969 427 Mt alum hd 435 Vette
            LW 1969 427 TH alum hd 435 Vette
            LO 1969 427 Mt HD 430 Vette
            LV 1969 427 TH HD 430 Vette
            LL 1969 427 TH HP 390 Vette
            LM 1969 427 Mt HP 390 Vette
            LN 1969 427 TH HP 400 Vette
            LQ 1969 427 Mt HP 400 Vette
            MS 1969 427 Questionable Vette
            LX 1969 427 TH SHD 435 Vette
            LR 1969 427 Mt SHP 435 Vette
            LT 1969 427 Mt SHP 435 Vette
            ME 1969 427 Mt 430 Vette
            MG 1969 427 at 430 Vette
            MH 1969 427 Mt 390 Vette
            MI 1969 427 at 390 Vette
            MJ 1969 427 at 400 Vette
            MK 1969 427 Mt 400 Vette
            MR 1969 427 Mt 430 Vette
            CTL 1970 350 4 spd trans. 300 4 Vette
            CTM 1970 350 tur 400 300 4 Vette
            CTN 1970 350 high perf, a/c, m/t - 350 4 Vette
            CTO 1970 350 h/p, a/c, m/t - 350 4 Vette
            CTP 1970 350 h/p, t/ign., m/t - 350 4 Vette
            CTQ 1970 350 h/p, t/ign, a/c, m/t - 350 4 Vette
            CTR 1970 350 spec hi perf, m/t LT1 370 4 Vette
            CTU 1970 350 H.E.I., sp hiper, m/t LT1 370 4 Vette
            CTV 1970 350 s h/p, m/t, t/ign. LT1 370 4 Vette
            CZL 1970 454 Mt HD 465 Vette
            CZN 1970 454 TH HD 465 Vette
            CZU 1970 454 Mt HP 390 Vette
            CGW 1970 454 TH LS-5 HP 390 Vette
            CRI 1970 454 Mt LS-5 HP, ti 390 Vette
            CRJ 1970 454 TH LS-5 ti 390 Vette
            CGS 1971 350 4 spd trans. - 270 4 Vette
            CGT 1971 350 tur 400 270 4 Vette
            CGZ 1971 350 m/t, 4 spd LT1 330 4 Vette
            CJL 1971 350 m/t, 4 spd 270 4 Vette
            CJK 1971 350 tur 400 LT1 330 4 Vette/Chevelle/Monte
            CGY 1971 350 H. D. 4 spd LT1 330 4 Vette/Monte
            CPH 1971 454 Mt LS-5 365 Vette
            CPJ 1971 454 TH LS-5 365 Vette
            CPX 1971 454 TH
            I hope you dance
            • Edward M.
              • November 1, 1985
              • 1922
              I concur. I'll dig into it and see what I can find out. Whatever I find will get added to the Lime Book. Right now I have SH - 1963 - 327- Passenger Car just based on what I see here. Stay tuned...
              • David L.
                • July 31, 1980
                • 3310
                My 1963 Chevrolet Parts Catalog (Oct. 1962) does not list a "SH" code. Note that the code on 327 engines with a M.T. always start with the letter "R" and 327 engines with P.G. always start with the letter "S". The "SG" code is for a 1963 Passenger car 327 w/P.G., H.P, and A.C. Logically a 1963 Passenger car with a "SH" code would have even more options.
                Did marine or industrial/agricultural applications use Powerglide transmissions?
                My 1963 Chevrolet Truck Parts Catalog (Oct. 1962) for 1.5, 2, and 2.5 ton 1963 trucks lists the following codes for 327 engines: ""U", "UA", "UB", "UE", and "UF".
                Since the block was made in Tonowanda it would be installed in a Corvette. Note that there is no code for a 1963 Corvette w/P.G. and A.C. I believe that the A.C. option was only available on "late" 1963 Corvettes.
                My 1964 Chevrolet Parts Catalog (Oct. 1963) has the same list of codes for 1963 models.
                Dave
                • Jerry W.
                  • January 27, 2009
                  • 588
                  KC donor car for this engine makes sense since the 62 was delivered to mid-state Missouri ( NCRS Delivery data)and top side of engine was stock vette components ( heads , intake and dist. )....Thanks to all for help
