66 Non A/C Heater Box Gaskets - NCRS Discussion Boards
  • Brian K.
    • September 19, 2007
    • 174
    I am rebuilding my heater box and the AIM isn't clear if both gasgets go on the inside of the firewall or one in and one out. ANybody know please?
    Thanks!
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
    • 6941
    Re: 66 Non A/C Heater Box Gaskets
    Brian, there are gaskets on both sides.
    • Brian K.
      • 174
      But it looks like the core mount plate gets sandwiched between the two gaskets. One on the heater box then the plate goes on then on the other side of the plate gets a gasket and that goes against the inside of the firewall and no gasket on the outside. That's wrong?
      66 Coupe
      66 Convertible
      2022 2LT Coupe
      67 Chevelle SS396
        • 6941
        Brain, if we are talking about the fiberglass boxes inside compartment and the box in the engine compartment there is a gasket on perimeter of each box.
          Brian -
          The core plate and the core arrived at St. Louis as part of the heater assembly from Harrison; the gaskets shown in the A.I.M. are external to the core plate.
          • Brian K.
            • 174
            Ed & John,
            Thank you both very much. The last time the core was installed, Buba had glued a gasket to each side of the core plate. That's what confused me.
            As I see it, the round tube seals are not used on the 66, right?
            Also the foam seal on the inside of the car (that has reliefs cut into it) is just glued to the box over the outside, right?
            Thanks again!!!!
            66 Coupe
            66 Convertible
            2022 2LT Coupe
            67 Chevelle SS396
              Ed & John,
              Thanks again!!!!
              Brian -
              The round core pipe foam seals are '63-only. The large C-shaped foam seal goes on the heater box first, then the inner rectangular seal.
