'62 340hp oil capacity - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1363
    Just bought a '62 340hp car. Owner's manual says total oil capacity for this engine (and all '62 327's ) is 6 quarts when changing filter. Is this correct?
    '62 340hp
    '67 L79
    '67 L36
  • Larry C.
    • April 1, 1980
    • 279
    Re: '62 340hp oil capacity
    Correct. But if uncertain as to correct oil pan, dipstick etc, you can put in 5 qts with new filter and run engine for short period and check to see if 1 qt low.
    Larry
    • Terry D.
      • May 31, 1987
      • 2692
      William
      Agree with Larry, but if someone put the wrong tube and dipstick on the motor, you still might not get an accurate reading. Been there done that with a 62 Bubba put together.
