1967 Grille Restoration - NCRS Discussion Boards
  • Richard G.
    • December 20, 2012
    • 15
    I need to restore my grille on a 1967 Corvette. Need Help & Suggestions.
    Richard Green (57800)
  • Paul J.
    • September 9, 2008
    • 2091
    Re: 1967 Grille Restoration
    Richard, there are several detailed discussions on this in the archives. Here's one of hundreds:
    https://www.forums.ncrs.org/showthre...ghlight=grille
    I seem to recall that there was an article on this in the Restorer also, but I'm not sure about that.
    Paul
    • Gerald C.
      • June 30, 1987
      • 1283
      Richard,
      How bad is the grille? I just did mine and took out the minor scratches by hand with a polishing compound> The painted portion was in good shape. My suggestion is to do an awful lot of masking and match the gray paint in flat. It's pretty simple to do, just takes a lot of time.
      Good Luck
      Jerry
      • Mark D.
        • June 30, 1988
        • 2151
        Pitting is your biggest roadblock. Richard Fortier has the original mask used for painting and has restored 3 66/67 grills for me. I couldn't be happier with the results.
        Kramden
