c1 rear springs - NCRS Discussion Boards
c1 rear springs
  • Patrick M.
    • July 20, 2012
    • 50
    c1 rear springs
    When assembling the rear 4 leaf springs does the two banding clips go towards the front of the car and one in the rear? Thanks Pat McPherson
  • Rod K.
    • 443
    Re: c1 rear springs
    Two towards the front on the second and third leaf ends, and one to the rear on the second leaf end.
    • Keith R.
      • August 31, 2001
      • 660
      Re: c1 rear springs
      Do the cut edges of the banding point towards the center line of the car or away from the centerline?
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      2013 427 Convertible
      Shade tree mechanic and
      B-52 pilot extraordinaire
      • Rod K.
        • 443
        Re: c1 rear springs
        Keith, I'm no expert on this, but just guessing I'd say the orientation was probably random if they were done by hand or all the same direction if done in a fixture (most likely). Suggest contacting the Team Leader for the year in which you're interested for guidance. Maybe this will bump it up for some add'l comment.
        • Bill M.
          • April 1, 1977
          • 1386
          Re: c1 rear springs
          It did. Here's the original banding on my '59:
          • Keith R.
            • August 31, 2001
            • 660
            Re: c1 rear springs
            So, any of you recognize this kind of banding that was on my springs? PS. The dates match the build date of the car so I have no doubt that they are the original springs. We're any C1s banded in this manner?IMG_2420.JPG
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
            • Thomas H.
              • August 31, 2005
              • 1060
              Re: c1 rear springs
              Originally posted by Keith & Gina Mac Rae (36692)
              So, any of you recognize this kind of banding that was on my springs? PS. The dates match the build date of the car so I have no doubt that they are the original springs. We're any C1s banded in this manner?[ATTACH=CONFIG]49206[/ATTACH]
              Interesting as I just picked up a set of springs for my 58 that have the same banding. No spring liners either. I'm assuming that this was a reworked spring somewhere along the line, but I'd be interested to see what others have to say.
              Tom
              2007 Z06, Lemans Blue
              • Troy P.
                • February 1, 1989
                • 1284
                Re: c1 rear springs
                Reworked. You can still easily find those steel strap clamps at your local spring rebuilders.
                • Mike E.
                  • February 28, 1975
                  • 5140
                  Re: c1 rear springs
                  Absolutely reworked!
                  • Thomas H.
                    • August 31, 2005
                    • 1060
                    Re: c1 rear springs
                    Does anyone have a reference measurement I can use to tell if the springs I just picked up are "saggy"? If I were to lay them on the floor, eyelets on the ground, arch up and measured from the ground to the top of the arch, what should I measure?
                    Right now I measure 6" from the floor to the top of the arch. These springs have no liners between the leafs (why, I have no idea) so with liners it may be closer to 6.25".
                    Am I saggy??
                    Tom
                      Re: c1 rear springs
                      Am I saggy??
                      Tom
                      Tom -
                      Dale Pearman's notes on that subject said that a properly-arched C1 spring would measure 5-1/2" to 5-3/4" from a straight line between the eye centers down to the top of the main leaf.
                      • Troy P.
                        • February 1, 1989
                        • 1284
                        Re: c1 rear springs
                        They should measure 51 inches center of eye to center of eye. You can test the flex knowing that the average rate of deflection is 115 lb/inch.
