Re: L-46 Dyno Runs Part 2
I quoted the peaks that EA showed in the data table from 2000 to 6500 in 500 RPM increments. Being as how the torque and power curves near their respective peaks are fairly flat, there is little difference in the predictions plus or minus 500 revs from the peaks, and you can also see that this is the case in your test results data table.
EA predicted torque at 3500 was 368 lb-ft and predicted power at 5500 was 338.
Simulation programs will not produce exact results to three significant digits, but if they are accurate within a few percent they can be a very useful tool. The best way to use them is by establishing a baseline. I've used test data I've gathered over the years on known OE configured engines to tweak the input parameters to give the best correlation. Then from this baseline changes can be made - like head flow or valve timing to see their effect on the performance curves. The absolute numbers may be off a little, but the errors apply to both cases equally, so the DIFFERENCES, expressed in percent are usually quite accurate.
