egine id - NCRS Discussion Boards
egine id
  • Richard C.
    • July 31, 2001
    • 144
    egine id
    please help? pad#cla192120, cast#3970010, cast date? 0 6or8 then7? intake man #8827184, date cast? 6org, 1 8or9? tranny main case,3925660, p9k03a, 19s724978, side cover, 3952648, tail housing, 3857584GM, tag on side cover, 3950356. thanks richard.
  • William C.
    • May 31, 1975
    • 6037
    Re: egine id
    What year car are we looking at?
    Bill Clupper #618
    • Wayne M.
      • March 1, 1980
      • 6414
      Re: egine id
      Originally posted by Richard Coolidge (36515)
      ....tranny main case,3925660, p9k03a, 19s724978, side cover, 3952648, tail housing, 3857584GM, tag on side cover, 3950356. ....
      Richard: don't know about the engine numbers, but your tranny is out of 1969 Corvette with VIN derivative 72S24978, assembled July 3rd 1969, wide ratio (and per tag 3950356) could be mated with a differential ratio from 3.08 thru 3.70.
      But your side cover is off a 1970-up trans.
      • Dan A.
        • May 31, 1974
        • 1073
        Re: egine id
        The 3970010 casting number is a well known 350 cu in. block which fits with the CLA suffix as this suffix was used in 1973 and 1974 in Corvettes with 190 hp 350s with a 400 automatic trans.
        Nailing down the casting date would be good, as it is my experience that the General sometimes used these suffixes in other vhicles in other years. Case in point, the CLA suffix was also used for 1972 Chevelle with a 240 horse 402 (396) automatic. Obviously not the case here.
        No offense, but your numbers as presented is a little "garbled".
          Re: egine id
          pad#cla192120,
          Richard -
          What exactly is stamped on the pad? There should be two separate stamps, each with different font sizes.
          • Richard C.
            • July 31, 2001
            • 144
            Re: egine id
            it is a 69, no other numbers on the pad. a mix match cvt i am working on!but happy to have the work! date code i will have to get a younger set of eyes to help, THANK YOU FOR YOUR HELP!!!!!!!
            • Michael D.
              • June 30, 1996
              • 536
              Re: egine id
              ...19s724978...
              VIN derivitive for 1969 Corvette #24978 assembled in July, 1969.
