Quick Question: Proper way to crank engine w/o starting? - NCRS Discussion Boards
  • Larry E.
    • 1674
    I know this has been discussed before; but maybe this is a little different.
    Question: What is proper way to crank a engine w/o starting it. Is it different
    from a T/I like a L72 vs. conventional like L68(with points)?
    Do you simply unhook the spark plug wire from the distributor to the coil and
    just let it hang in the air w/o touching anything or should it be it be grounded?
    Also I assume you unhook it from the coil side vs. distributor side or does it
    make a difference? Thanks in advance. Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Quick Question: Proper way to crank engine w/o starting?
    if you have a TI i would unplug the black box (amplifier) to make sure you don't do any damage to the electronics
    • William C.
      • May 31, 1975
      • 6037
      I'm with Clem!
      Bill Clupper #618
      • Larry E.
        • 1674
        Clem:
        OK; then what?? Do you still unplug the spark plug wire from the coil? Ground it? How about
        the non T/I car?? Thanks Again - Larry
        Larry
        • William C.
          • May 31, 1975
          • 6037
          If you disconnect the TI, there is no spark to ground. Nothing else to do.
          Bill Clupper #618
          • Larry E.
            • 1674
            OK; that settles the T/I cars and thanks. Now how about the non T/I with the points. Surely
            someone should know. Please Advise; Larry
            Larry
            • Clem Z.
              • January 1, 2006
              • 9427
              the best way is to disconnect the positive side of the coil so you don't have any spark jumping because if any gasoline is present you could have a fire.
