Took the 3x2 Holley carbs off of my 69 last week, as they were leaking. They're off for a rebuild now.
When I took the carbs off of the intake manifold, I found a black gasket under each one.
The center gasket was stamped in white ink "CENTER CARB TOP"
Each end gasket was stamped "END CARB TOP"
I pulled/scraped 'em off, as I had new replacements in my assortment of spare parts. I had installed these carbs myself about 12 years ago, BTW.
Got the new gaskets out yesterday. The bag is from a major Corvette supplier. The tag says it contains 3 gaskets, one center and two ends.
In looking through the bag, it contains FOUR gaskets
, all of them are identical.
What, if any, is the difference between what was on the car and what I have now? Is the center carb gasket somehow different?
Thanks for any insight. I do not have the carbs here for comparison, and the old gaskets were tossed in the trash several days ago.
Chuck
, all of them are identical.What, if any, is the difference between what was on the car and what I have now? Is the center carb gasket somehow different?
Chuck
