1969 3x2 Carb Gasket Question - NCRS Discussion Boards
  • Chuck G.
    • May 31, 1982
    • 2039
    Took the 3x2 Holley carbs off of my 69 last week, as they were leaking. They're off for a rebuild now.
    When I took the carbs off of the intake manifold, I found a black gasket under each one.
    The center gasket was stamped in white ink "CENTER CARB TOP"
    Each end gasket was stamped "END CARB TOP"
    I pulled/scraped 'em off, as I had new replacements in my assortment of spare parts. I had installed these carbs myself about 12 years ago, BTW.
    Got the new gaskets out yesterday. The bag is from a major Corvette supplier. The tag says it contains 3 gaskets, one center and two ends.
    In looking through the bag, it contains FOUR gaskets , all of them are identical.
    What, if any, is the difference between what was on the car and what I have now? Is the center carb gasket somehow different?
    Thanks for any insight. I do not have the carbs here for comparison, and the old gaskets were tossed in the trash several days ago.
    Chuck
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 1969 3x2 Carb Gasket Question
    if you put the original GM black gakets on wrong you had a vacuum leak. even the brown ones should have the word "REAR" stamped on them so you get them on correctly
    • John M.
      • January 1, 1998
      • 813
      Chuck,
      I think I remeber one of these gaskets was just flipped over for the center carb, but it's been a while so I'm not sure.
      I think it said "this side up for center". I could be completely off here.
      John
      • Chuck G.
        • May 31, 1982
        • 2039
        Thanks for the info. The 4 gaskets I have are all identical, and have no markings for rear and center and have no markings for top either. They're just plain old black gaskets, and they look identical on the top and bottom surfaces too. Wonder if I should order another set?
        Chuck
        • Chuck G.
          • May 31, 1982
          • 2039
          I just went ahead and ordered another "correct" set from Paragon. On their website, you can see one of the 3 gaskets pictured with the white writing "Top Center" of some such verbage. Says it contains 3 gaskets, one center and two ends. Shipping cost more than the gaskets.
          Chuck
          • Clem Z.
            • January 1, 2006
            • 9427
            same GM gasket from 2 different sides
            • Chuck G.
              • May 31, 1982
              • 2039
              Interesting. Thank you, Clem. I wish I had the carbs here so I could play with them and see what difference the switcheroo makes.
              Chuck
              • Clem Z.
                • January 1, 2006
                • 9427
                it is how the gasket sets on the manifold openings that is important
                • Chuck G.
                  • May 31, 1982
                  • 2039
                  Well, if that's the case, looks like I wasted about $20.00, but how would I know?
                  BUT, on the bright side, when I get these correctly marked gaskets, I'll mark the 4 that I will still have so I'll know for the next time,..................................
                  OR if/when I sell the car, I'll just pass them on to the new owner.
                  Chuck
