67 starter wiring - NCRS Discussion Boards
67 starter wiring
  • Al R.
    • June 30, 1988
    • 688
    67 starter wiring
    OK a search of archives did not turn up what I 'm looking. On a repo wiring harness at the starter, there is a pink wire, a purple wire, and a black/orange tied together. I know where they go. There is also a small gauge black wire with a large hole round terminal on the end. Does this go on the srarter mounting bolt (which i presume) or on the solenoid battery connection point? Thanks Al
  • Ralph S.
    • February 1, 1985
    • 935
    Re: 67 starter wiring
    Starter mounting bolt.
    • Donald H.
      • November 2, 2009
      • 2594
      Assuming the 67 is the same as 66, the Dr Rebuild wiring diagrams shows
      Pink goes to the 'R' terminal on the solenoid
      Orange/Black to the 'B' terminal
      Purple to the 'S' terminal
      14 gauge black with larger lug goes to Starter Mounting Bolt for ground.
      O
      n my 66, the ground wire is also a continuation of the ground plug on the blower motor and wiper ground. If this ground wire is not grounded at the starter the blower motor and wiper will not work.
      Don.
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • Al R.
        • June 30, 1988
        • 688
        Thanks Don and Ralph, I wasn't sure and didn't want to fry anything! Al
