1954 Horn Contact Verification Needed - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    I am beginning work on the horn system for my 54 and had a question regarding all of the horn contact parts found in the steering hub. All of the components and horn ring were missing on my car so I have little to go on. From a quick search of the past technical postings it has been suggested that the horn contact components used on the Corvette were identical to those in the 54 pass car. I have found this contact set on the Ecklers site and wondered if it is correct with all of the parts needed between the steering wheel and chrome horn ring.
    I have a chrome horn ring now and will be purchasing the emblem later. Am I on the right track if I purchase this kit?
    Second question would be the upper bearing and wire that is installed within the mast jacket...I do not have this yet and will install it when I rebuild the steering box - does the little spring-loaded horn contact button found in this contact kit ride on the outer rim of the bearing? Have not found a clear diagram yet when looking at the "Old Car Manual" site which by the way has been a load of help.
    Thanks!!
    John
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 1954 Horn Contact Verification Needed
    that is the kit
    install the upper bearing
    make sure there is no paint on the outer lip of the brg - that is what the spring loaded contact ride on
    make sure there is no paint on the inside of the steering wheel area
    the metal "spring" faces up towards the steering wheel
    you will also need the spring that goes over the mast - keeps the brg in the housing.....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Tim E.
      • April 1, 1993
      • 360
      John - To add to what Chris describes.....send me a note at tim.ehlers@att.net and I'll send you the pictures and notes I have. I just took mine apart and documented it pretty thoroughly. Tim
      • John L.
        • February 1, 2005
        • 207
        Thanks Chris - Thanks Tim for your helpful insights. should be able to figure out the beep beep now.
        Best,
        John
        • Chris S.
          • January 1, 2000
          • 1067
          if it goes beep beep - wrong horn - thats a road runner horn....
          • Tim E.
            • April 1, 1993
            • 360
            John - Look at the picture and diagram for Corvette Central's part number 561125 (Upper Steering Column Bearing) in their C1 catalog. That assembly fits into the steering wheel end of the steering column tube. The spring loaded horn contact rides on the brass surface you see at the edge of the tube with the bearing assembly installed. The wire you see goes through a connector and on to the horn relay. When this wire is grounded, the horn relay sends the + current to the horn. Horn buttons work by completing the circuit to a ground when you push on the horn ring. Tim
