'61 Dash Mystery Wire ID Needed - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    The wire in the photo with the blue tape and connector was found unconnected when I removed the dash. The wire appears to be grayish in color. Where is this wire supposed to go or is it an add on? Thanks!
  • Mike M.
    • May 31, 1974
    • 8400
    Re: '61 Dash Mystery Wire ID Needed
    almost all gray wires on a c-1 are energizing dash lites. ncrs sells a wiring diagram book that i've found extremely helpful when sorting out a wiring problem . the book, 1953-1972 Corvette Electrical Wiring Diagrams, can be purchased thru the good folks in cincinnati.(see membership). good luck,mike
    • Roger W.
      • January 29, 2008
      • 569
      The wire diagram in the service manual shows that the gray wires are dash lamps, including the cigarette lighter and radio. If you know where the other gray wires go, you should be able to see where the mystery wire goes through a process of elimination useing the wire diagram.
      • Larry B.
        • October 21, 2010
        • 254
        All grey dash lamp wires are already accounted for. This has a female connector on it. It could be a radio wire that has not been used for a long time. Does it look like the stock radio wire?
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11334
          That is likely for the cig lighter lamp, which has a pigtail on it to reach that connector. I'd bet your lighter was replaced at one time and they replaced it with the housing that didn't include the lamp.
          Note this is a reproduction....
          • Larry B.
            • October 21, 2010
            • 254
            I believe you hit the nail on the head Rich. Mine is gone. Thanks
            • Jerry W.
              • January 27, 2009
              • 588
              Looks like problem has been solved....He's a nice wiring diagram
              • Larry B.
                • October 21, 2010
                • 254
                Thanks for the diagram, Jerry!
