Battery hold down bolt for 1978 Corvette - NCRS Discussion Boards
  • Brian F.
    • November 1, 2004
    • 21
    • 43247
    Re: Battery hold down bolt for 1978 Corvette
    Originally posted by Brian Fox (42918)
    Are the 1978's battery hold down clamp different in some way to require longer bolts?
    Brian-----
    No.
    • David L.
      • July 31, 1980
      • 3310
      Brian,
      Are you sure that you are using the correct battery clamp (aka retainer)? See link below.
      68-70, GM # 3887588
      71-72, GM # 1383273
      73-81, maybe 82 Corvette as well, GM # 6270159
      82 Camaro, GM # 14005061 as per AIM
      3887588, 1383273, and 6270159 are very similar.
      GM # 14005061 (thick black plastic, about 1" thick as best as I can remember), see 2nd link below. My 1994 Z28 uses this battery retainer with bolt # 11515984 (M8 X 1.25 X 75, about 2.95" effective length.
      Dave
      http://www.gmpartsdirect.com/results...number=6270159
      • Tom R.
        • June 30, 1993
        • 4100
        The 78 AIM shows GM# 6270159 for the bracket with a GM# 3858700 bolt. The bolt is as Paragon describes
        Battery hold down bolt, “E” headmark, 5/16-18x1 1/4", w/pinch point and captured washer."
        but seems I recall that bolt to be about 1 3/4" in length. I'll check it later for you if you haven't received confirmation.
        Tom Russo
        78 SA NCRS 5 Star Bowtie
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Ralph S.
          • February 1, 1985
          • 935
          Are you sure you have the clamp with the right side facing up , i have seen some clamps upside down
            • 43247
            Tom-----
            The same battery hold-down clamp bolt assembly was used from 1968 through 1982, GM #3858700. This bolt had a captured flatwasher, pilot (pointed) tip, and a length, measured from underhead to the tip of 1.42"
            As far as I can tell, it was never available in SERVICE.
            • David L.
              • July 31, 1980
              • 3310
              Joe,
              My Chev. Dealer Parts and Accessories Price Schedules (Sept. 1976 and Jan. 1978) list GM # 3858700 in Gr. 16.323 (door parts) for $0.10 (list price) stocked at "GMT" (General Motors Truck Division Warehouses). GM # 3858700 was discontinued sometime between Jan. 1976 and Dec. 1981 as per my GM Parts History Catalog.
              Dave
              • Tom R.
                • June 30, 1993
                • 4100
                Tom-----
                Does it look like this?
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                  • 43247
                  [ATTACH=CONFIG]43056[/ATTACH]
                  Tom------
                  Yes.
                  • Brian F.
                    • November 1, 2004
                    • 21
                    Hi Tom,
                    That's the same "ELH" bolt head on my low mile Pace Car. What do the letters mean? The threads on the bolt measures about 1 3/8" compared to the one Zip Corvettes sent me which is less than 1" long. Their bolt only has an "E" stamp on it.
                    Still, as I do research on the many Corvette online catalogs, their bolts seem shorter than what's needed on my other car. It's nice to have a Vette in the garage that I can cross reference as I'm trying to get this other Pace Car ready to sell.
                    Where do I go to find the correct length bolt?
                    • Tom R.
                      • June 30, 1993
                      • 4100
                      I picked this one up from Carlisle...swap meet by browsing through tables of misc hardware. It measures 1 3/8" in length.
                      Tom Russo
                      78 Pace Car L82 M21
                      00 MY/TR/Conv
