Source to rebuild / replace internal heater box parts? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 961
    The internal sheet metal parts for my 68 heater box is pretty much gone. I have tried to find sources to replace the internals but no luck. Anyone have a resource for repairing the insides of the heater box?
    Thanks again
    Pat
  • Michael M.
    • February 15, 2007
    • 455
    Re: Source to rebuild / replace internal heater box parts?
    Do you mean the box where the heater core is located? Or the air plenum under the dash on the right side of the car with the swinging doors on the inside?
    • Patrick N.
      • March 10, 2008
      • 961
      The actual heater box where the heater core is located. The few sheet metal baffles are in bad condition and rusted through in a couple areas. If possible, I'd like to remove and replace these internals with new sheet metal.
      Pat
      • Harry S.
        • July 31, 2002
        • 5349
        I suggest you look for another box. I'm more familiar with C2's and have never seen those parts reproduced.
          • 43295
          Harry and Patrick-----
          Yup. If you want to restore your original heater box you'll need to find another to salvage the internal parts from (or, just use the used heater box as-is).
          GM never sold any components of the heater box separately (except the heater core clamp which attached with a screw). I know of no reproduction source for any of the components.
          • Patrick N.
            • March 10, 2008
            • 961
            Thanks guys, that's what i figured might be the case since nothing turns up anywhere in my search for parts. On to plan B.
            Best,
            Pat
            • Ralph S.
              • February 1, 1985
              • 935
              What years are the same heater box with no A/C
              • Harry S.
                • July 31, 2002
                • 5349
                This is a C3 question correct?
                • Mark D.
                  1984-96 Team Leader
                  • June 30, 1988
                  • 2179
                  Big City seems to carry ducting and such. Maybe they can help.
                  Kramden
                    • 43295
                    Ralph------
                    1968------GM #3014762
                    1969------GM #3018741
                    1970-74---GM #3023565
                    1975-79---GM #3031625
                    So, how were these different? I do not know. But, they were different.
                    • Dick W.
                      • 10483
                      Mullikins Corvette in the Spartanburg SC area has many C3 parts. In addition to his existing inventory, he purchased truck loads of parts at the Corvette parts auction we conducted last year.
                      Dick Whittington
                      • Patrick N.
                        • March 10, 2008
                        • 961
                        Thanks for the lead Mark and Dick, I will give Mullikins and Big City a try, thank you.
                        Joe- I did see on L.I.C. web site the 67 heater box "looks" the closest to the 68. Out of curiosity, do you have a part number on the 67 no-AC heater box?
                          • 43295
                          Patrick-----
                          It was GM #3859394
                          • Scott M.
                            • January 1, 1996
                            • 216
                            Are the parts so far gone that they can't be brazed up? The internals in our '76 had some rust as well but I managed to salvage it by fabing up some sheet metal patches, welded and ground them smooth.
