*** Frame Stencil *** - NCRS Discussion Boards
  • Blair K.
    • September 27, 2012
    • 170
    In regards to my early model '68 (Nov.24/1967 build date) L36/M40, what would be the correct number that is stenciled on the frame (passenger side)??? My stencil is long gone. What size (inch) characters ??? What would be an acceptable date? Any photos of what the stencil on the frame would look like would be awesome. Thanks in advance. BK
    • 6955
    Re: *** Frame Stencil ***
    Blair, Vendors like Paragon Corvette will make up a stencil for that is correct. they'll ask you your VIN and if you do not have a idea of when it should be dated they will use a birthday caculator. The stencil does go on the passenger side toward the rear part of the door. You should be able to find some pic.s in the archives.
    • Blair K.
      • 170
      Thank-you, sir, for the info. Much appreciated. I was not aware of this. I will check into it.
        • 3418
        Hi Blair,
        Perhaps this will give you some idea what you're looking for. You can judge it's position from the hole in the frame rail.
        This is an original from a 71. I'm not sure how the typical stencil for your 68 may vary from it. Maybe in the size of the characters?
        Might there be a 68 stencil picture in the new 68-69 TIM & JG?
        REMEMBER the CAR is upside down in this picture.
        • Blair K.
          • 170
          Thanks Alan for the great picture of your frame stencil. Very well preserved. I am going to check mine and hopefully it has stood the test of time and I will be able to read some of the numbers. BK
          • Mike E.
            • June 24, 2012
            • 920
            Here is an image of the '66 chassis line. I would go by the relationship to the #3 crossmember gusset. I can't say if placement was much different in '68.
            Mike
