65 Coupe , Vent Window Repair - NCRS Discussion Boards
  • Richard T.
    • February 1, 1979
    • 858
    The drivers side vent window on my 65 coupe has a broken hinge. The small right angle tab that's spot welded to the window frame has broken at the bend. I thought I would just locate another frame, install my glass and go. It isn't that easy. Just finding a good used frame is tough enough but if you can find a usable one the price is outrageous. Is there anyone out there who repairs these frames? How about a good source for a new or restored part. Rich
  • Alan D.
    • January 1, 2005
    • 2046
    Re: 65 Coupe , Vent Window Repair
    Friend just sold a NOS one for $178, he said LI Corvette has the tab just not sure how one welds on.
    • Larry M.
      • January 1, 1992
      • 2701
      Contact Virginia Vettes. They are a supporting vendor on the "other forum". Go to that site for a link, or "google" the name for contact information. They do this repair.
      Paragon may be another source for repair.......but not completely sure on this.
      Larry
      • Harry S.
        • July 31, 2002
        • 5330
        Rich, I just received the new tabs (upper and lower) and rivet from LIC. The installation process is to remove the frame, remove the old broken tab and old rivet. Then spot weld the new lower portion on the frame. You may need to re-seat the rivets in the upper tab or replace it with new rivets if that is bent also. Then install the new swivel rivet to attach the lower tab to the upper tab. It is just a very labor intensive process.
        Good Luck
