'61 Steering Wheel Configuration - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    Re: '61 Steering Wheel Configuration
    Here you go guys let me know if the column looks has seen the presence of Bubba.
    • Mike E.
      • February 28, 1975
      • 5141
      That looks good. I'd disassemble, clean, relube, and then install the corrected steering wheel and hub in the correct configuration. If the switch is good, and wiring good, you're a go.
      • Bruce B.
        • May 31, 1996
        • 2930
        #18
        Larry,
        Here are a few pictures of the bottom of the hub on my 57
        Hope this helps.
        I agree with Mike, your turn signal mechanism looks good and just needs a good cleaning.
        Bruce B
        • Larry B.
          • October 21, 2010
          • 254
          #19
          Thanks Mike & Bruce! What dash bulb numbers should be used and are they all the same? Of course I have an assortment in there now.
          • Mike E.
            • February 28, 1975
            • 5141
            #20
            All the gray ones should be 57. Don't have my resources in front of me, but I believe bulbs are listed in the owners manual.
            • Doug F.
              • November 1, 1983
              • 322
              #21
              i use 57's on the gray like mike says and 53's on the rest of them
