'61 Steering Wheel Configuration - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    I have the steering wheel removed in order to remove the dash. I am not sure if the wheel was configured correctly on the shaft. Does someone have a photo of the steering wheel in the straight ahead position indicating how the wheel and horn contact should be orientated?
    Thanks!
  • John F.
    • March 23, 2008
    • 2415
    Re: '61 Steering Wheel Configuration
    There should be an index mark on the steering shaft. Hope these photos help.
    • Larry B.
      • October 21, 2010
      • 254
      Thanks John. My horn button was at the 7 o clock position.
      • Mike E.
        • February 28, 1975
        • 5141
        When the mark on the shaft is straight up, the two pins should be on the left side, at approx 8 and 10 o'clock. (vertical, parallel to the shaft).
        • Larry B.
          • October 21, 2010
          • 254
          Which pins?
          • John G.
            • January 1, 2006
            • 85
            I assume the "pins" referred to are the turn signal cancelling roll pins on the underside
            John G
            • Larry B.
              • October 21, 2010
              • 254
              Thanks John I only have one pin! That why I didn't see the other.
              • Mike E.
                • February 28, 1975
                • 5141
                Needs to be two--you should be able to see where the other went. Both are critical, in terms of position, for the turn signal to properly function. if one pin is missing, it's probably broken off because it (the steering wheel) was improperly positioned (clocked).
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Larry,
                  The 2 roll pins are pressed into the steering wheel hub which in inside of the bell and stick out about 1/2 inch.
                  Do a discussion board search for the exact dimension) , I believe this has been discussed before.
                  If you need a roll pin (or 2) email me and I can drop then in the mail.
                  Bruce B
                  • Larry B.
                    • October 21, 2010
                    • 254
                    Attached is a photo. How could I repair or attach a pin?
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      Larry,
                      I can't see and I can not enlarge your picture but I assume the pin is broken off in the hole.
                      If so , since the roll pin is hardened I don't think you can drill it out.
                      If you can remove the wheel from the hub (it looks like it might be held on by screws) do that and locate and drill a hole over thre roll pin from the top down to the pin.
                      Then knock the pin out using a small punch.
                      Then you can install the new pin.
                      • Larry B.
                        • October 21, 2010
                        • 254
                        I am not sure were the pin is that you are talking about. Below is a better picture. I thought the pin was the tab sticking out in the picture. I do not see any other pins.
                        • Bruce B.
                          • May 31, 1996
                          • 2930
                          Larry,
                          The hub pictured is not a typical C1 hub, I'm not sure what it is from.
                          I will try and post a picture later tonight or tomorrow.
                          Bruce B
                          • Mike E.
                            • February 28, 1975
                            • 5141
                            That plate on the back is by bubba. Take it off. Just visible beyond that plate's outside edge, at 2 and 4, are the holes for the roll pins. Now show us a picture of the mechanism in the cup on the column--let's see what may be bubba-ized there, too.
                            • Larry B.
                              • October 21, 2010
                              • 254
                              Thanks Bruce. From what I recently learned, that plate does not belong as was added for what purpose I don't know. I will PM you with my address if you can send the roll pins. A picture of what it should look like would be great!
                              Thanks again.
