11:1 Pistons for 283 - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    Someone told me that the forged 11:1 Chevy pistons for the 283 engine are no longer available. If they are, can someone steer me to a source? I'd rather not have to go aftermarket because most of that stuff is very pricey.
    Bob
  • Mike M.
    • May 31, 1974
    • 8382
    Re: 11:1 Pistons for 283
    call dean or john at cresap machine( 301 724 8794) as they got me such pistons couple years ago. mike
    • Mike M.
      • May 31, 1974
      • 8382
      PS: they can masage the 548 283ci to end up with 334 ci, so i'm told.
      • Vinnie P.
        Editor NCRS Restorer Magazine
        • May 31, 1990
        • 1567
        HA!!!!! So you've been told...I think that quote probably comes from first hand knowledge...
          • 15667
          Are you talking about a '61? I believe those were the only 283s that used "11:1" forged pistons for the FI engines. Prior FI engines with the Duntov cam were rated at 10.5:1, and the pistons were cast. I believe Danchuck offers a repro, but I don't know who manufactures them.
          Check Sealed Power/Speed Pro and also check other piston manufacturers like Venolia or (forgot the name) in Huntington Beach, CA.
          All use a forged blank that I believe is sourced from Federal Mogul. They can machine most OE designs or machine a customized design for a reasonble fee.
          In today's CNC machining world, as long as a suitable forged blank is available, nearly any piston design can be machined. Same thing with camshafts.
            • 15667
            He already 'fessed up in The Corvette Restorer, remember? But I think that cheater motor is actually 338 CID.
            • Dick W.
              • 10483
              What's a few cubic inches amongst friends??
              Dick Whittington
                Egge makes 283 domed pistons - they started making them about five years ago.
                  • 43219
                  Duke-----
                  No original 283 pistons were forged material. All were conventional cast using permanent mold. Most were cast at GM's Bedford, IN aluminum foundry.
                  The first forged pistons for a small block were 1962 340 and 360 HP.
                    • 43219
                    Originally posted by Bob Baird (39424)
                    Hi all,
                    Bob
                    Bob-----
                    As I responded to Duke, forged pistons for a 283 were never available from GM.
                    The 11:1 cast aluminum pistons for 283's, GM #3769731, lh, and GM #3769732, rh, were discontinued without supercession in 1982. So, these pistons have not been available in 30 years!
                    • Loren L.
                      • April 30, 1976
                      • 4104
                      Bob-----
                      If you want a set of cast, dial 602-254-9586 and ask for Bill. I have a set in the LM car.
                        • 15667
                        Duke-----
                        Okay. I'll try to remember that. Since the '61 FI engines had higher compression than prior years, I thought they might be forged.
                        The manufacturer in Huntington Beach, CA whose name slipped me at the time is JE Pistons.
                        Over the past 20 years we've had a few small lot runs - like 10 to 12 sets - of Cosworth Vega pistons machined by JE from proper forged blanks in several different dome volumes to achieve CRs from the OE 8.5:1 up to about 10.5:1
                        • Ed H.
                          • November 1, 1999
                          • 626
                          Bob,
                          In my drag racing days I used JE 12.5 pistons. I had JE flycut the valve pockets and cut a flash pocket for the spark to reach across for an Isky 550 flat tappet cam. That engine is still alive in a very fast boat in the unblown, small C/I class. This in a 334 C//I, 548 block, with two bolt mains. JE may still make lower compression pistons. With todays gas and ignitions I would be a little leary about 11 to 1, that is unless you have a source for 100+ octane fuel. Be careful of the skirt to wall clearence, street driving vs. racing. You did not say what the engines purpose will be used for. JE will build your pistons with full floating wrist pins, oil hole drilled and all. You would have to have the rods drilled at the top for oil to pass through to the bronze bearing that are pressed into to them. With this type of set up, and a blue printed lower end it should last forever, depending on the RPM attained.
                            • 43219
                            Duke-----
                            JE has been a manufacturer of premium custom made pistons for many years. Of course, they also have a line of premium off-the-shelf pistons. I think they even have a line of "budget" pistons under another brand name (maybe "SCE" or something like that).
                            • Dick W.
                              • 10483
                              Duke-----
                              JE has been around for at least 50 years. I used Venolia, JE and Forgedtrue in the early '60's.
                              Dick Whittington
