Ignition Coil - NCRS Discussion Boards
Ignition Coil
  • Joe C.
    • August 31, 1999
    • 4598
    Ignition Coil
    I have an old Delco Remy coil, embossed "238" "B-R", which I'd like to use as a backup. Can anyone tell me what it was originally used in, if it used an external ballast, and if possible, what the internal resistance is.
    Thank you.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Ignition Coil
    Here's what's shown in the P&A era catalogs for service.
    1969 Rev July'69 Chevrolet, incl. Corvette:
    '67-'69 1115238 All, Corvette -----w/1.3 Ohm wire, stamped 238_BR
    (compare to) 1115202, '68-'69 All, exc. T. Ign --- w/1.8 Ohm wire, stamped 202-12V
    My Jan '70 P&A30 (Corvette only):
    the 238 is the same for '67-'70
    the 202 is Corvette '55-70 w/12 volt (exc. T.Ign) w/1.8 Ohm wire
    • David L.
      • July 31, 1980
      • 3310
      Re: Ignition Coil
      Joe,
      My 1967 Chevrolet Parts Catalogs, incl. the Corvette (April & July 1967) lists GM # 1115238 for the following:
      67 PASS. (8 cyl.)(exc. P.G.).
      My 1968 Chev. Parts Catalog (Oct. 1967) and 1969 Chev. Parts Catalog (Oct. 1968), incl. the Corvette list GM # 1115238 for the following:
      67-68 PASS. (8 cyl.)
      Apparently no Corvette application in 1967 and 1968 according to the 1967, 1968, and 1969 parts catalogs.
      My 1968 Corvair-Chevy II-Chevelle-Camaro Parts Catalog (July 1968) lists GM # 1115238 for the following:
      67 CHEVY II, CHEVELLE, CAMARO (8 cyl.) (exc. 302, 396, H/Per.)
      68 CHEVELLE, CAMARO
      description: COIL, Ignition w/1.3 ohm (stamped 238-BR)
      Dave
        • 43247
        Re: Ignition Coil
        Originally posted by David Liukkonen (3775)
        Joe,
        68 CHEVELLE, CAMARO
        Dave
        Dave and Joe-----
        The GM #1115238 coil eventually became the SERVICE coil for all 1967-74 Corvette standard ignition applications.
