'66 front valance header bar and clips - NCRS Discussion Boards
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 993
    I'm in the process of restoring a '66 convertible and am now at the front valance header bar (St. Louis body). Can someone confirm the original color/finish of the header bar and the four clips that hold the wiring harness?
    Thanks...Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: '66 front valance header bar and clips
    The header bar is black on a St, Louis body.
    • Russ S.
      • April 30, 1982
      • 2163
      The clips are green unless by chance they got hit with blackout.
      • Tony S.
        • April 30, 1981
        • 993
        Thanks guys. The four clips that I removed appear to have a rubberized coating over a portion of the clips.
        • Kim C.
          #3844390 wire clip on header bar AIM section 12 A4.0
          doing research on these clips , coated vs uncoated, please post year and if clips you have were coated or uncoated - also the 63 aim shows 5 clips, 64,65,66,67 AIM show 4 - how many clips do you have
          • Gene M.
            • April 1, 1985
            • 4233
            Actual original cars have 4 clips. I come across clips with coating as well as clips with out it. Most of the clips I noted were phosphate plated, also seen green chromate finish. I do not recall the years that each type were on. My guess is GM had multi source suppliers on these parts thus the differences. Maybe someone on this board has the original drawings that define finish and coating.
            • Alan D.
              • January 1, 2005
              • 2055
              Mar64 car - 4 clips coated & all original.
              Interesting that those clips are at the head lights to keep the harness away from that mechanism.
              • Timothy B.
                • April 30, 1983
                • 5203
                To add a little, the early 63's used the same attachment straps as what's used on the inner fenders to hold the wire harness.
