Paint Chip Repair Methods (?) - NCRS Discussion Boards
  • Anthony S.
    • April 30, 1998
    • 156
    All, does anyone have a good (successful) process to repair small chips in body paint (1 to 2 mm in diameter?). I am looking for
    approaches for both Lacquer paint and today's base coat clear coat types. Where the end result is a nice smooth finish with the
    existing paint & good color match. Thanks Tony
  • Michael J.
    • January 27, 2009
    • 7136
    Re: Paint Chip Repair Methods (?)
    I tried Dr. ColorChip for my '67 Rally Red lacquer, the color matched well, and the small stone chips were harder to see, but not totally gone. I needed several applications to fill the chip.
    • Dick W.
      • 10483
      Anthony, your local autobody supply store should have small "Q" tip like applicators. For paint, I have used model aircraft/car paint. You may have to buy two bottles to blend to match your color. Take your time, apply a "dab", let it dry and do it again. If done carefully the chips are hard to find.
      Dick Whittington
      • Michael M.
        • February 1, 1993
        • 604
        You can get away with stone chip repair with solid colors very easily. When you get into metallic colors it a whole different story. What color are you working with?
        • Dan P.
          • December 1, 1990
          • 683
          There are guys who repair chips for used car dealers . Call around maybe a Uses Car dealer will give you a name . Or Google Chip repair .
          • Michael J.
            • January 27, 2009
            • 7136
            Actually, the best ones I have ever seen are usually associated with Mercedes or Porsche dealers, but they ain't cheap....
            • Bill S.
              • April 30, 2002
              • 154
              Try This
              http://www.youtube.com/watch?v=bkYrfTMkYfw
              Bill Strobel
              Owner Independent Towing
              Fayetteville, NC
              1979 Corvette White/Red L-82 4 spd
              Only 4,200 miles
              Do It Right or Don't Do It At All
              • Kurt G.
                • April 30, 2005
                • 343
                Another way to repair small rock chips is to use a small syringe, like an insulin syringe and carefully apply the paint to the middle of the chip and fill the hole. It will take several applications to completely fill the chip bu you don't have to worry about smudging the area around the chip and the finished product looks great with solid colors. But, like was said earlier its a different story with metallics. I'm lucmky that my wife is diabetic so getting the syringes is easy for me. But, if you are good friends with you doctor you might be able to talk him into a prescription for a few if you don't have the luck I have.
                Kurt Geis
                Chairman, Midway USA Chapter
                Targa Blue 1972, Top Flight and Duntov Award, 2014
                Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                Arctic White 2013 60th Anniv Special Edition Conv.
