67 Corvette Chassis Markings, Stampings and Casting Numbers - NCRS Discussion Boards
  • Thomas N.
    • July 31, 2002
    • 402
    I am in the process of taking apart a very rustfree 67 chassis and thought I'd post some pictures of the markings and such I have found so far. The first posting is of the driveshaft. After removing paint which was applied about 30 years ago, you can clearly see the green and orange stripes applied to the driveshaft. Also, where the paint was rubbed away, you can see that the tubing used to manufacture the driveshaft had a very shiney finish to it. I've also included a picture of the driveshaft stripes with a ruler to gauge the width and location of the stripes.
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
  • Thomas N.
    • July 31, 2002
    • 402
    Re: 67 Corvette Chassis Markings, Stampings and Casting Numbers
    Enclosed are pictures of the rear end crossmember. Pictures show the part number, and the dana logo stamped into the crossmember. Also you can see a small dana logo on the corner piece of that is part of the weldment.
    • Thomas N.
      • July 31, 2002
      • 402
      Enclosed are LM stamping on the transmission mount, the SS stamping on the exhaust center bracket, The AAC stamping on the rear strut rod bracket, and the sp marking on the gas tank bracket.
      • Thomas N.
        • July 31, 2002
        • 402
        Enclosed are paint markings for the front spindle castings. It appears that there is only paint applied to one end of the castings, not both ends.
        • Thomas N.
          • July 31, 2002
          • 402
          Enclosed is a blue paint marking on the manual steering pitman arm, and pictures of the tie rod end castings.
          • Thomas N.
            • July 31, 2002
            • 402
            Enclosed are pictures of the manual steering drag link. It appears to be silver hammertone painted. I welcome comments as to the originality of this finish on this part. It appears to deviate from the Judging Guide.
            • Thomas N.
              • July 31, 2002
              • 402
              And a detail of the markings on a tie rod end, along with the -10 stamping on the gusset of the frame.
              • Michael J.
                • January 27, 2009
                • 7156
                Very interesting pictures. Is this an unrestored survivor car? How many miles? Interesting that the paint stripes on the driveshaft don't show much separation like the ones on Shelbys do, but the driveshaft material (shiny) was the same. And the DANA stamp is surprising, I didn't know that DANA built these parts for GM, I thought they were only Mopar manufacturers. Thanks, good history.
                • Bill H.
                  • August 8, 2011
                  • 439
                  Thanks for the pics Thomas, especially the spindles.
                  Off the top of my head, the numbers and marking is identical to my 67, even the double Dana stamping.
                  My driveshaft has the small gap.
                  • William L.
                    • December 1, 1988
                    • 944
                    Great pictures Thomas. Thank you for posting them.
                    Bill Lacy
                    1998 Indy Pacecar
                    • Kenneth B.
                      • August 31, 1984
                      • 2091
                      Dana made many parts for GM & Ford also.
                        • 6950
                        Tom, nice pic.s , I think what your seeing is from the forging process. I have the same on my 63 and 72 after cleaning the grease from those parts.
                        • Gary B.
                          • February 1, 1997
                          • 7054
                          Tom,
                          I agree about the remnants from the forging process. It looks similar on some vintage NOS strut rods I have stored somewhere in my collection.
                          Gary
                            Tom -
                            Great photos, nice detail! The bright spots you see on the steering relay rod are from the trim die that trimmed off the parting line flash remaining from the forging operation.
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Thomas,
                              Here are pic's of an NOS 63-67 relay rod. The surface is black from end to end.
