1963 Door locks - NCRS Discussion Boards
1963 Door locks
  • Bob R.
    • June 30, 2002
    • 1595
    1963 Door locks
    I am replacing the incorrect reproduction locks on the doors of my 63 but I am not sure which way the lock is supposed to go. Turn to the rear of the car to lock and to the front to unlock? I am not certain they are correct now and a friend of mine wasn't certain the judging manual was correct. I appreciate any help.
  • Rick A.
    • July 31, 2002
    • 2147
    Re: 1963 Door locks
    Bob,
    The "key" to the entire problem is, when you insert the key into the lock when installed on the car, the teeth are down on either side.
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Bob R.
      • June 30, 2002
      • 1595
      Re: 1963 Door locks
      I understand the key is facing teeth down but I believe they are handed and opposite each other. If installed on the wrong door they will lock and unklock in the wrong direction. To the rear to lock and to the front to unlock? or the other way around?
      • Tom H.
        • December 1, 1993
        • 3440
        Re: 1963 Door locks
        Driver door locks by turning key clockwise. Passenger door locks by turning key counterclockwise.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
