This for my 1960 restoration. I've got the new wiring harness all in and everything works except the heater blower motor. I can jumper a ground to a blower motor mounting bolt and it will work, so I know it is a ground issue.
There is no separate ground wire and the motor assembly mounts to the fiberglass heater core box which then mounts to the firewall. So I can't figure out where it gets a ground?
Don
Don
