1964 Fuel Pump - NCRS Discussion Boards
1964 Fuel Pump
  • Larry M.
    • March 1, 2002
    • 62
    1964 Fuel Pump
    I need a fuel pump for my 64 327-365hp. What is the correct pump, and where is a good place to buy one? Thanks for any info...
  • Bob H.
    • July 31, 2000
    • 813
    Re: 1964 Fuel Pump
    Should be a 40083. Available rebuilt but will be expensive. Use someone in the Driveline. Is yours for sure wrong or is it bad? If bad make sure it is not a correct one as you can buy a rebuild kit.
      • 43222
      Re: 1964 Fuel Pump
      Larry-----
      You need an AC type 40083 fuel pump. This pump has been continuously available from 1964 until the present day from GM/AC-Delco. However, it's configuration has changed somewhat over the years. So, even though you can still buy one new, it's not exactly the same as the one originally installed on your car. One feature that has changed over the years is the bottom plate of the pump. If I recall correctly, the originals had a convex, stamped steel bottom plate.
      The 40083 is a screw-type, rebuildable pump. So, if you can locate an original, used pump, you can rebuild it like new. Where to get one? The Driveline ads would probably be a good place to start.
      • William C.
        • May 31, 1975
        • 6037
        Re: 1964 Fuel Pump
        Original 40083 was unique in that it used a magnesium casting for the top as opposed to the normal "pot metal" zinc die castings used on most pumps. Very noticeable by the dark color that the magnesium acquires given exposure to air over time. Also the inlet and outlet are 180 degrees from each other as opposed to the configuration used on most pumps for lower HP applications. Also "40083" stamped on the outer edge of the flange.
        Bill Clupper #618
        • David L.
          • July 31, 1980
          • 3310
          Re: 1964 Fuel Pump
          I have had two 40083 pumps over the years, one was stamped "40083" and one was stamped "40083 IJ" (Sept. 1970). The 2-letter stamped date coding started about 1965 and the Fall of 1964 for some AC pumps (example "4657 LD" dated Dec. 1964). For your 1964 you want the "40083" pump.
          Dave
