1967 BB 400HP/AC car Radiator catch tank - NCRS Discussion Boards
  • John M.
    • June 27, 2010
    • 179
    I have a roadster 427/400 HP A/C car with PowerGlide tranny. Do they have a radiator drain tank? I pretty sure they do not however I was wondering if not why not? My car has just got back on the road after 35 years of restoration. After I returned from a break in ride the cooling system burped and I got thinking what if this happens when in traffic? I installed a new Radiator cap to see if that helps.Thanks for reading.
    Re: 1967 BB 400HP/AC car Radiator catch tank
    John -
    Your radiator should have a brass hex plug (early cars) or a brass petcock (later cars) near the bottom of the driver's side tank. See your Assembly Manual, section L36, sheet A5, View "C", item #8.
    • Keith B.
      • March 7, 2008
      • 928
      John I think he is talking about a over flow tank. if so then the answer is no. GM did not use over flow tanks in 67. if you have the coolant level correct and all the variables correct for the cooling system it should never puke
      • Kenneth B.
        • August 31, 1984
        • 2089
        It could be not all the air in the block/cooling system was blead out before you put the cap on.
        • Stuart F.
          • August 31, 1996
          • 4676
          How big of a burp was it and a description of what happened and where would help. I lost most all of my coolant when a thermostat stuck closed and the resulting overheated coolant puked out of the overflow as the cap did it's job.
          Stu Fox
            • 43221
            John-----
            The only 1967 Corvettes that had a radiator SUPPLY TANK were all small blocks and L-88 big block. No others, at all.
            Prior to 1973 no Corvette was originally equipped with a radiator RECOVERY TANK.
            • James M.
              • April 4, 2011
              • 6
              I have a 67 coupe 427/390 that I bought new. From new, after a drive, a few minutes after shut down it would puke coolant, even with the coolant at correct level. I got tired of adding coolant, so after awhile, I used a windshield washer bottle as a overflow tank. Works great.
              • John M.
                • June 27, 2010
                • 179
                I changed the radiator cap that seems to be helping I'll find out sunday after I get to take it out. Thermostat seems to be working, she runs about 190-200. Thanks for the help.
