1954 Acellerator Kick Down Rod Lever at Transmission- Information Needed - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    I need some help in identifying the correct lever or bellcrank that attches to the drivers side of the transmission that the accelerator kick down rod attaches to. As I recall the shaft on the transmission that this attaches to is a low speed shaft but cannot recall for certain. I have see levers that are straight and others in an "L" shaped. Having a time finding this little guy. A photo for reference would be most helpful....
    John Lanning
  • Peter R.
    • June 19, 2011
    • 233
    Re: 1954 Acellerator Kick Down Rod Lever at Transmission- Information Needed
    John, Hope this picture helps--it's a little fuzzy. Pete
    Pete
    1954 Corvette #814
    1957 Corvette #646 -- FI, 3-speed
    • John L.
      • February 1, 2005
      • 207
      Thanks Peter - good photo of what I should be looking for...
      Now to find one.
      John Lanning
      • Troy P.
        • February 1, 1989
        • 1284
        I'm pretty sure this is the same lever used on passenger cars. If so they should be everywhere. Check early parts books to confirm.
        • Guy M.
          • November 1, 1993
          • 500
          John, nothing like a treasure hunt, I think I have what you need. PM me with your address and Ill send it. Merry X-mas. Some one did that for me and I was most appreciative. Guy
          • John L.
            • February 1, 2005
            • 207
            Guy - Thank you so much...will PM you......that is what is so great about this forum and members. We are trying to help each other through our respective projects. I will do the same for another too.
            Best,
            John L
