1966 A.I.R aircleaner base - NCRS Discussion Boards
  • John M.
    • January 1, 2000
    • 175
    I have a A.I.R aircleaner base marked 1966 427, its diffrent then others I have had, it has the two one inch outlets in the normal postions and the welded stud, it has a third one inch outlet where the base has a blank spot, I havent seen one with a third outlet, teach me somthing......Thanks JOHN
  • Ara G.
    • January 31, 2008
    • 1108
    Re: 1966 A.I.R aircleaner base
    John
    I can't explain or give any info about the third outlet, but it was my understanding that all 66 427 motors were smog exempt...only the small blocks got smog if going to a California dealer in 66.....Best Regards....ARA
    • David L.
      • July 31, 1980
      • 3310
      John,
      According to the 1966 Corvette AIM the air cleaner asm. used on the 427 eng. w/A.I.R. is part # 6421963 as shown on UPC K19, sheet A4. In the drawing it appears that hose # 3884655 is connected on the passenger side, hose # 3888363 is connected on the back side, and hose # 3889356 is attached on the driver's side. The stud which is located on the driver's side is used to attach clamp # 3885003 (UPC K19, sheet A5).
      GM # 6421963 is also listed as the air cleaner asm. for the 1966 Corvette w/A.I.R., H.P. 427 in my 1966 Chev. Parts catalog (Oct. 1965) in Gr. 3.402.
      Can you post a few photos?
      My 1967 Corvette AIM lists GM # 6423689 as the part number for the air cleaner asm. for the 427 eng. w/A.I.R. as shown on UPC K19, sheet A4.
      The air cleaner shows only one tube which connects to hose # 3884655. GM # 6423689 does not appear in my 1967, 1968, and 1969 Chevrolet Parts catalogs (Apr. & July 1967, Oct. 1967, and Oct. 1968) but list GM # 6421963 for 1966-1967 Corvettes w/A.I.R., H.P. 427 eng.
      GM # 6421963 was replaced with GM # 6484413 in March 1970 as per Chevrolet Parts History.
      Dave
      • Ara G.
        • January 31, 2008
        • 1108
        John
        I might have not been as clear as I should have been in my original post...It was my understanding that the 427/425 or 427/450 cars were SMOG exempt..I am trying to attach the thread from the DB from July 12, 2012 that was a thorough explanation/discussion on the topic...Dave, out of curiosity are the items you listed relegated to a 427/390 car? I am curious....Thanks...ARA thread https://www.forums.ncrs.org/showthre...ht=air+cleaner
        • David L.
          • July 31, 1980
          • 3310
          Yes, L36 option, 390 HP 427
          • Ronald L.
            • October 18, 2009
            • 3248
            John, I've seen your base for sale, what was listed earlier this week it is not a 66 427 390 HP Cali smog base, one too many tubes.
              • 43248
              John
              Ara-----
              That's how it was. 1966 with L-36 delivered to California had AIR; L-72 did not. The same basic thing applied to full size Chevrolet and Chevelles for 1966. L-36 in full size Chevrolets had AIR; L-72 did not. For Chevelles, the base 325 HP 396 and the L-34 360 HP 396 had AIR; the L-78 375HP 396 did not. I may have forgotten a lot of things but I recall this all very well.
              For 1967 things changed. All Corvettes delivered to California had AIR with the possible exception of L-88. There were probably only a handful of L-88's delivered to California and, if they ever had AIR, it was probably removed the first day it was delivered to a customer.
