62 rear end - NCRS Discussion Boards
62 rear end
  • Roger B.
    • June 30, 1991
    • 82
    62 rear end
    My rear end back case has indent on right side facing front.
    Is this correct?
    thank you
    Roger
  • John F.
    • March 23, 2008
    • 2406
    Re: 62 rear end
    Roger, Not sure what you are trying to say. Can you post a picture? Tom Parsons has posted a number of pictures on rear assemblies. you may want to search.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17654
      Re: 62 rear end
      Roger,
      Photos of a 62 rear end. Hope this helps.
      Gary
      62 Rear End Housing v1.jpg62 Rear End Housing v2.jpg62 Rear End Housing v3.jpg
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Roger B.
        • June 30, 1991
        • 82
        Re: 62 rear end
        GARY, THANKS, I'M REFERENCE TO THE INDENT ON THE LEFT SIDE FACING THE REAR, AS IN PHOTO #2.
        THIS IS WHAT MINE LOOKS LIKE.
        THANKS AGAIN GARY.
        rOGER
        • Patrick S.
          • January 1, 1988
          • 209
          Re: 62 rear end
          Would the picture be an "early" 62 rear with the drain plug in the bottom? Later units have no drain plug.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17654
            Re: 62 rear end
            Patrick,
            Sorry I should've stated the back photo is from a 57-8 rearend. Was intent on showing the indenture. Couldn't find the back photo of the '62 unit.
            Gary
            NCRS Texas Chapter
            • Graeme B.
              • October 23, 2007
              • 213
              Re: 62 rear end
              My rear end has an indent in the middle.
              • John F.
                • March 23, 2008
                • 2406
                Re: 62 rear end
                Not sure if these help.
                • Roger B.
                  • June 30, 1991
                  • 82
                  Re: 62 rear end
                  are there gear ratio stamped on the left side of pumpkin facing rearward?
                  Roger
                    Re: 62 rear end
                    Roger
                    Roger -
                    On C1's, the ratio code (and assembly date) are stamped on the right sideof the pumpkin, on the as-cast surface that faces forward.
