color / paint on 71 wiper arms - NCRS Discussion Boards
  • Peter B.
    • July 31, 2000
    • 155
    Hi guys
    What is the color / paint of the wiper arms fora 71?
    Mine has over-spray from a previous bad paint job so I cant tell. They look to be in OK shape other than having to replace one of the spring pins.
    Any ideas?
  • Paul O.
    • August 31, 1990
    • 1716
    Re: color / paint on 71 wiper arms
    Peter
    Here are a few photos from a 1971.
      • 15645
      Originally posted by Peter Bouza (34477)
      Hi guys
      Any ideas?
      The wiper arms on early C3s are not painted. They were originally plated before the arms were assembled. As I recall from the print there was three different plating operations, depending on the material involved. If you are interested in going to that length, I can look for the print. The end result was a dark (mostly black) dull non-reflective finish. Perhaps someone here has successfully mimicked the finish with paint and will offer their technique.
        • 3422
        Hi Terry,
        Did the washer fluid tube and it's soldered attachment to the wiper arm receive that plating operation too?
        Regard,
          • 15645
          Hi Terry,
          Regard,
          Yes but I have to type more for the computer
          • Patrick N.
            • March 10, 2008
            • 954
            Regarding refinishing, what do most do to restore the wiper arms? Is there a suitable paint to touch up if the finish is not too badly gone but needs some attention?
            Pat
