63 Alternator issue? - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2158
    OK, hear's a good one: my 63's volt meter goes crazy at 2800 RPMs. It Jumps rapidly from discharge to charge. I'm guessing this is an alternator problem, but I'm looking for some help with this, so any opinions would be welcome.
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Timothy B.
    • April 30, 1983
    • 5201
    Re: 63 Alternator issue?
    Mike,
    I would take the alternator and voltage regulator to a old fashion repair shop that rebuilds these parts and have them tested. It will take you three times longer to take them off then have them tested.
    The shop will spin the alternator at different rpm's and you will know for sure if there is a problem with either of these two parts.
    • Michael G.
      • November 12, 2008
      • 2158
      Thanks Tim, I'll do that.
      Mike
        • 6955
        Mike, just make sure to check all the electric connections that are tied in with the alt and regulator try the wiggle test to with someone watching the amp meter.
        • Timothy B.
          • April 30, 1983
          • 5201
          Mike,
          One more thing, if you have the original #512 voltage regulator don't let it out of your sight even if it's bad..
