Came across a 870 block with stamping of s-282154 F060rb Can anyone decpher this ?......Thanks in advance.......Kirby
Engine stamp help
Re: Engine stamp help
Robert -
300hp manual trans. '62-'64 pass. cars used the "RB" suffix; the "R" suffix was used for '62-'64 250hp pass. cars with manual transmissions.- Top
John, Isn't it generally believed that the 250 hp pass car engine was a Towanda cast and not a Flint, yet there was a Flint cast 870 "R" block on ebay a month back.- Top
Robert,
Depending on which Chevrolet model you bought the engine blocks came from either Flint or Tonawanda plant. If the Chevrolet was built in Flint Michigan you can be sure the heavy stuff came from the closest plant.
I think it was discussed here a while back that all crankshafts came from Tonawanda.- Top
Robert -
870 blocks were used in virtually all Chevrolet car and truck lines, and were cast at both Saginaw (for Flint V-8) and at Tonawanda. The only 327 block I'm aware of in that era that was cast only at Tonawanda was the 3858180.- Top
