A/C hoses for '69 - NCRS Discussion Boards
A/C hoses for '69
  • Jeffrey S.
    • May 31, 1988
    • 1899
    A/C hoses for '69
    Hello all! I'm still looking for the length of the suction side hose that goes from the compressor to the POA valve on a '69 small block. I posted this question several times and as yet have not gotten a response so if you can help it would be great. I plan on having my original hose set rebuilt with crimped ends so I need to get a length since mine was shortened many years ago.
    Thanks!
    Jeff
  • Michael G.
    • March 2, 2008
    • 487
    Re: A/C hoses for '69
    Jeff, I know my hoses are original but it's a '71 small block. I don't know if similar or not but happy to measure mine in the AM if you can use their measurements.
    • Jeffrey S.
      • May 31, 1988
      • 1899
      Michael,
      That woud be great! I don't know if the routing of yours is the same as for '69 but I would guess that it is. If you could also take a picture and post it, it would really help.
      Thanks very much!
      Jeff
      • Michael G.
        • March 2, 2008
        • 487
        OK Jeff, here we go. Aluminum end off compressor is at the 4:00 angle and rubber hugs the rear wall of inner fenderwell. She then becomes other metal end which goose-necks down, in towards engine, and up to valve. The exposed rubber portion is 14" between metal fittings. I am unable to get a photo through fender. She is disabled very close to garage wall for current project. Let me know if more is needed. Hope these photos help.
        • Michael G.
          • March 2, 2008
          • 487
          003.jpgThe photos should come with this Jeff. Let me know if they don't.
          • Michael G.
            • March 2, 2008
            • 487
            002.jpgAnd here's another one for you.
            • Michael G.
              • March 2, 2008
              • 487
              I realize these photos are not the greatest help and the shots you need are through the fender which I cannot provide at this time. Hope my description is helpful.
              • Jeffrey S.
                • May 31, 1988
                • 1899
                Michael,Thanks very much for the photos and measurement. As it happens, this evening we were having ice cream and a fellow drove in with a '72 A/C car with original hoses. I measured his and it was the same as you indicated (14 "). Just to be sure I understand the routing as you described: the hose goes down from the compressor towards the inner fender. Then goes back up to the POA valve. The '69 has a bracket attached to the inner fender through which the hose passes, holding the hose close to the fender, which later years may not have.
                Jeff
                • Michael G.
                  • March 2, 2008
                  • 487
                  That's correct Jeff. No hose bracket on mine and I don't beleive there ever was. Lower hose end does a 180* upward u-turn and connects to valve.
