Hi, I have a 65 roadster, had to replace a nonfunctioning sender. The gauge works fine when activating the sender boom manually-that is when I raise the float the gauge moves to full.
The problem appears to be that the float level needs to be altered to give a true reading. That is, when the
tank is half full, the reading is 1/4 or less.
So question is does the float need to be positioned lower or higher in the tank? Not easy to do it by hand-I have tried. But which way? Seems it should be lowered, but now not so sure. Thanks.
