Water Pump Restoration - NCRS Discussion Boards
    • 43259
    Re: Water Pump Restoration
    Originally posted by Larry Mulder (20401)
    I don't believe that the 230 F represents a failure point, but is probably the maximum SUSTAINED/CONTINUOUS temperature that the o-ring is rated for. For our older cars with the 180 F thermostat, this shouldn't be a problem. For the newer Vettes that are almost always running in the 220-230 F range, a better rubber compound is likely needed.
    Larry
    Larry------
    You're correct. However, I don't like "living on the edge".
    Incidentally, the part involved is not an o-ring. It is the bellows component of the waterpump seal.
      • 15621
      Originally posted by Bill Hetzel (53669)
      230 doesn't even kick on the secondary fan..............on my 92.
      Only one fan on my 2008, and I don't know when it kicks on -- but at 230 the AC goes off, and outside air is ducted into the cabin.
      I will have to look up the 1995 Caprice. I think the secondary fan comes on at over 230 on that one.
      • Carl N.
        • April 30, 1984
        • 592
        #18
        attached is a cross sectional drawing for a JC Type 1 seal - one of the most common and oldest - you will note the o-ring in the cross sectional on the seat (which would be ceramic or ni-resist for hot water) and the bellows ( the dark "Z" part) in front of the spring on the rotary head - yea I know way more info then anyone asked for and not really relevant to the original issue of this post !
