Denso W14P-U plugs - NCRS Discussion Boards
Denso W14P-U plugs
  • William F.
    • June 9, 2009
    • 1364
    Denso W14P-U plugs
    Anybody know where I can purchase these nonresistor extended tip plugs? The resistor version is available but Denso has discontinued this non resistor version. Found 6 on Amazon, but need 2 more-none on flea bay.
    '67 L79
  • Jack H.
    • April 1, 2000
    • 477
    Re: Denso W14P-U plugs
    How about these: http://www.sparktecmotorsports.com/w14p-u.html
    I have a '67 L79 also. Are these "THE" plugs to use in your opinion?
    • Bryan H.
      • August 31, 2004
      • 120
      i purchased them on EBAY by doing the search....werent cheap but still cheaper than the original A/C's
      • Dennis O.
        • December 1, 1988
        • 438
        Geez, I'm really sorry guys; I bought 8 from a guy in Canada. and he said he was sick and tired of dealing with the drama, so he sold me the rest of his inventory for $.50 per plug. I have enough for my cars, so I am open to selling a couple of sets for a reasonable price. I am not looking to screw over anyone, so the prices will be reasonable.
        PM me.
        • William F.
          • June 9, 2009
          • 1364
          I'm interested in these Denso plugs since they are non resistor and in my experience, L79's need a good spark to get to redline without a miss. Duke also likes the U groove electrode; so I thought I's try to find some. Do others think the resistor veersion of this plug or other resistor brands such as AC R45S (extened tip which is in engine now-Denso also extended tip) are just as good? Am I working too hard to find a nonresistor plug?
            • 15706
            If you can find W14-U, which is a non projected tip plug and equivalent to the AC 45, why not use them. Also, the NGK B4 is equivalent to the Denso W14-U and AC 45.
            • William F.
              • June 9, 2009
              • 1364
              Dennis,Let me know what you want for them and I'll buy a set. I also sent you an e-mail on same subject.
              William Ford
              '67 L79/C60 marina blue/bright blue coupe
              • William F.
                • June 9, 2009
                • 1364
                Duke,
                Don't you not think the extended tip design offers better non fouling properties? I run a mixture of leaded race gas (I know, I know, but my engine has close to actual 11:1 compression) and non ethanol 93 pump gas; so, I'm going to get more chance of fouling due to lead.That's why I want the extended tip-your thoughts?
                  • 15706
                  As long as you stick with the equivalent of AC heat range 5, I don't think there will be any difference between the normal tip and extended tip as far as fouling is concerned.
                  The L-79 has a very lazy centrifugal curve and 93 PON = 98 RON, so I question your need for leaded race gas. Have you tried straight 93 PON pump gas and tested for detonation?
                  • William F.
                    • June 9, 2009
                    • 1364
                    Sparktec doesn't have any.
                    • William F.
                      • June 9, 2009
                      • 1364
                      Unfortunately, Dennis's were the non extended tip version. Anybody know where to get W14P-U extended tip plugs? Accell #8170(same as their 137) looks like a Denso W14P-U but cross references to a 44 heat rqange. Their #138 jumps to a 46 cross reference heat range. Anybody used either of these Accel plugs?If choice between a nonresistor nonextended tip vs resistor extended tip plug in 45 heat range on an 11:1 compression L79, which would you choose?
                      • John D.
                        • June 30, 1991
                        • 875
                        I'm morally opposed to using anything named Denso in my 67 Corvette.....have same AC 45's in car for over ten years and it runs fine..
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          Originally posted by William Ford (50517)
                          I'm interested in these Denso plugs ..... Duke also likes the U groove electrode; so I thought I's try to find some.
                          Here's the U-groove electrode on a Denso W16FS-U.
                          • Dennis O.
                            • December 1, 1988
                            • 438
                            I am morally oppossed to over spending; have you priced AC45's lately?
                            • John D.
                              • June 30, 1991
                              • 875
                              AC Delco R45S are $2.29 each at Autozone...
