'69 A/C hoses again - NCRS Discussion Boards
'69 A/C hoses again
  • Jeffrey S.
    • May 31, 1988
    • 1888
    '69 A/C hoses again
    On July 12 I posted that the big hose from the A/C muffler (small blocK) that runs to the POA valve blew out. While I am replacing this hose, I thought I would also replace the other hose that goes from the expansion valve to the drier. The AIM indicates that the part number 3949930 was added on 10-14-68. This appears to be a hose with the fittings on the end crimped on rather than what is now on my car (and I believe to be original) which has the fittings clamped to a hose as in '68. Since my car was built in Oct '68 I'm thinking that early cars had clamped on ends. Can anyone confirm this? Anyone have an early A/C small block car with these hoses?
    Jeff
  • George D.
    • August 31, 2000
    • 225
    Re: '69 A/C hoses again
    Jeff,
    I have a 69 built Nov 19, 1968. I can look tonight to confirm, but I think one of the hoses had a crimped on fitting. I did replace the large hose and had to use clamps since there was no acceptable replacement.
    George
    • Jeffrey S.
      • May 31, 1988
      • 1888
      George,
      Thanks for your help. All of the hoses coming off of the compressor are crimped. Also, if you can, could you take a picture and of these hoses and post here so I can see the routing of the hose that goes to the POA valve?
      Jeff
