1967 shifter adjustment gauge - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    Hi,
    Can anyone give me the dimensions of this gauge. I know they are cheap, but the S & H will be five times as much and this is a one time use.
    I've had my tranny rebuilt and have to readjustment the linkage arms, so the gauge is where I need to start.
    The back-up light switch rod doen"t line up either.
    Jerry
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 1967 shifter adjustment gauge
    I made one from and old beer can opener. Cut the end off and use the flat part. It's about 5/8" wide. The dimensions may be in your shop manual. If you haven't installed the linkage yet you can measure the slot.
    • Wayne W.
      • April 30, 1982
      • 3605
      Still say you don't need a gauge. I have never used one. Just lay a drill bit on the back where the relief is and bump all of the levers to it. Actually can just look at it and tell.
      • William C.
        • May 31, 1975
        • 6037
        I'm with Wayne, never needed one and that includes the setup I powershifted at the drags a few years back, with a stock shifter! Just line up the notches and you will be fine.
        Bill Clupper #618
          • 6960
          Jerry, I maybe a day late and a dollar short, but I like to adjust the shift levers while the trans is on the bench. a drill bit will work.
          • Gerald C.
            • June 30, 1987
            • 1314
            Thanks everyone.
            When I got the trany back from being rebuilt, I did not "readjust" the linkage, I made the assumption that the linkage adjustments would remain the same. Bad assumption as the tranny and shifter are in the car already!!!
            Looks like I've got a project this morning!!
            Live and learn
            Jerry
            • Gerald C.
              • June 30, 1987
              • 1314
              Thanks to everyone for helping me with this project. The diagram for the correct gage from John Hinckley was great. I modified it somewhat and used the narrower end to align the shifter arms while the shifter was out of the car. Then I taped the gage in position and then installed it in the car. I then removed the tape and gage after the sifter arms were adjusted and attached. It shifts great!
              My thanks!!
              Jerry
