65 SB fan blade - NCRS Discussion Boards
65 SB fan blade
  • Jim R.
    • June 30, 2001
    • 643
    65 SB fan blade
    I just noticed the other day that my (non air) 65 365 has on it a fan blade from a 63 a/c car or early 64 a/c car it has more pitch and is 18" across with the mushroom head rivets , reads the words front and a letter H stamped into it,my question is it hard to find a good original 17-1/8 with flat rivets for my 65, I see that someone makes a reproduction fan , anyone try one of these and is the quality good.
  • Clark K.
    • January 12, 2009
    • 536
    Re: 65 SB fan blade
    I cannot answer your question in regard to the quality (or NCRS judgeability?) of repro fans. But, if you have the seven-bladed fan, know that it is a rare piece. It is worth some money and possibly you could trade the 7-bladed fan for a correct original non-A/C fan (common) and some money.
    -Clark
    • Jim R.
      • June 30, 2001
      • 643
      Re: 65 SB fan blade
      Hi Clark I shoud have mentioned that mine is the 5 blade 63-early64 with A/C 18" with the 34.5 pitch blades. jim
      • Tony S.
        NCRS Vice President, Director Region VII & 10
        • April 30, 1981
        • 990
        Re: 65 SB fan blade
        Try Pete Lindahl. He should have a correct original.
        Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
        Original member of the Kansas City Chapter, est'd 07/11/1982.
        Member: 1965 and 1966 National Judging Teams
        Judging Chairman--Kansas City Chapter.
        Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
        • Peter L.
          • May 31, 1983
          • 1930
          Re: 65 SB fan blade
          Jim - From the description it sounds like you have the is the Hays-Albion fan blade assembly used on 63, 66, & 67 sb Corvettes and other GM passenger cars equipped w/C60.
          The 66 & 67 sb Corvettes and other GM passenger cars could have also come equipped with Switzer Clutch (SC) 18" dia fan blade assembly. The 64 & 65 Corvettes w/C60 used a 7 blade 18" dia fan blade assembly.Pete
          • David L.
            • July 31, 1980
            • 3310
            Re: 65 SB fan blade
            The 58-63 Chev. Pass w/AC, 61 Chev (348), and 61-63 Chev.(327,409) models used a 18" dia. 5-blade fan w/dome type rivets, GM # 3749576. GM # 3749576 was replaced in July 1964 (as per Chev. Parts History for over the counter parts) with a GM # 3789562 fan (18" dia., 5 blades, generally flat head rivets). The 3789562 was used on various 64-67 Chevrolet models w/AC and 66-67 Corvettes w/AC. The 3749576 and the 3789562 fans were made by Hayes-Albion. I have a few 3749576 fans but they are damaged.
            The 3789562 fan is listed in the 63 AIM for 63 Corvettes w/AC but from what I have heard over the years it was never actually installed on the 1963 Corvette assembly line. The base fan (GM # 3770529) apparently was installed on AC models. I have no documentation, just "here say" information.
            The 3863137 fan (18" dia, 5 blades) was made by the Schwitzer Company and stamped with the Schwitzer part number 912239 as well as a date code. This fan was also used on 66-67 Corvettes w/AC and other 65-67 Chevrolet models w/AC as well.
            Dave
