Lacquer Paint Source - NCRS Discussion Boards
  • Edward S.
    • December 1, 1986
    • 514
    Can anyone out there recommend a source for Lacquer Paint - I have a 65 Maroon Coupe that was painted in Lacquer 5 years ago, the paint that was left over from that painting is not a good match now. My painter just had some delivered and it's a worse match
    then my old stuff. Problem is The car is in great shape paintwise except for the hood - so we are trying to match it. Any information
    is appreciated. NY/NJ/Pa area would be great, but would like the best no matter where it's located. Thanks.
  • Michael M.
    • February 1, 1993
    • 606
    Re: Lacquer Paint Source
    Edward, to get lacquer paint and expect the color to match dead on is a tall order. Is it possible to find out what brand of lacquer was used when the car was painted last? I would start that way and your painter should suggest tinting the lacquer you do get by spraying test panels to get a good color match.
    • Donald T.
      • September 30, 2002
      • 1319
      Huge supplier of Automotive Paint, Auto Body Supplies, Airbrush Equipment, Car Detailing Supplies, Pinstripe Paint, Spray Guns & Safety Respirators at Wholesale Prices. Our items are factory direct and we carry a wide variety of Top Quality Brands.
      • Edward S.
        • December 1, 1986
        • 514
        Hi Michael, don't expect a dead on match. Would like to get closer then what we have now before we start tinting. Thanks for such a fast reply.
        • Russ S.
          • April 30, 1982
          • 2163
          then my old stuff. Problem is The car is in great shape paint wise except for the hood - so we are trying to match it. Any information
          I am very curious as to why the left over paint no longer matches. Has the car sat out side a lot in the past 5 years?
          • Joseph M.
            • June 30, 1999
            • 334
            Hibernia Restoration in New Jersey sells lacquer. They can be reached at 973-627-1882.
            • Dick W.
              • 10483
              I would guess that air pressure, technique, temp, familiarity of using lacquer, and/or humidity make the difference in the match.
              Dick Whittington
              • Keith B.
                • December 1, 1991
                • 398
                I just purchased my paint in Ohio today. B &W Paints in Toledo has an expert paint match specialist (Doug). They use PPG paints because Dupont has discontinued their laquer paint as well as RM. I used a gas cap for the match. It will take three days to complete. He only mixes a quart and sprays out several samples. He matches the color in sunlight , flourescent, etc. Once the color is right his mixes the remainder of the paint and resprays to assure consistency. I have seen his work and have been very impressed. It is very pricey at $600 per gallon. I also purchased red oxide primer (laquer) to make the car even more "originally" restored.
                Keith Burmeister
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Use the "close match" paint and flash the areas around the hood (ie, fender tops, cowl and headlight panel.
                  It may not be a good match but it will fool the eye.
                  • Edward S.
                    • December 1, 1986
                    • 514
                    We do intend to do the entire top surround
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      Keith & Ed, show us the results when done, we all need help in the area pf paint.
                      • Loren L.
                        • April 30, 1976
                        • 4104
                        I believe that I would take my leftover paint (if there's enough to do the top surround) and the gas lid door (if representative of the color today) or a wiper grill (or ???) to a paint store with a computer reader and be prepared to mix and match more than once. If you were here in Arizona, I know where I would send you, but.......
