I'm collaborating with a member of the Northern Califonia Chapter who is also a graduate of the U. of Wisconsin Engine Research Center and spent his career with Chevron on an article about modern gasoline for the Corvette Restorer. We want to sort out all the issues, separate the facts from the myths, and propose some action to help with problems members are experiencing.
In that regard I need some data. For those of you who have IR guns, I need carburetor/FI fuel meter temperature data.
With the car fully warmed up after a drive, remove the air cleaner and shoot the carburetor bowls. Also shoot other areas on the carb and report any differences over about 5 degrees. My hunch it that the whole carb will be at a fairly uniform temperature.
It will be easy on FI since nothing is in the way of a direct shot to the fuel meter.
Please identify the model year, engine option (by RPO ID or advertised HP), approximate ambient temperature, and whether the heat riser is operating properly, wired open, or the passage is blocked. If NOM or modified, specify the displacement, manifold material, and carburetor type.
Report your data in this thread. Thanks!
