Re: Ethanol Laced Modern Gasoline -Carburetor and FI fuel meter temperatures
Duke,
Here are some more numbers for you. Ambient temp +/- 68-70 and the numbers are at shut down and 5 minutes after. I used an IR gun from Harbor Freight (can't comment on accuracy, but seems to work fine). 1966, 327/300 4spd. with no mods.
Temp gauge: 175/180
Thermostat housing: 174/163
Fuel line from pump to carb: 166/170
Frame rail to pump: 118/112
front of carb: 150/145
Rear of carb: 160/155
Shooting the the carb near the mixture screw resulted in higher temps - mid 170's as I recall. But, I didn't write them down.
Duke,
Temp gauge: 175/180
