I purchased new armrest covers and ready to install them. Were they padded? If so, what would I use that is similar to original padding?
I also installed new bottom seal on the side window and polished the stainless steel frame. Will the window go back into the door if the garnish molding and the reveal molding are in place?
The ST-12 doesn't say anything about removing the two moldings before taking the window out of the door. If I insert the window first, then install the two moldings, I don't see how I would be able to get the fasteners on the moldings. The window raised up is in the way and the window down prevents access to the bottom of the two moldings. Advice would be appreciated.
The glass will bind in those areas if you don't. The repro fuzzies are too thick.
