Need help fixing a side terminal battery. - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Need help fixing a side terminal battery.
    i had a shorted battery blow up in my face also but i was fortunate that i wear corrective lens all the time and there was a water hose near by
    • Domenic T.
      • January 29, 2010
      • 2452
      A short while ago one of the airport workers went to start a transportation cart and the battery blew during the start cycle.
      I was to busy to go look at it but it got his attention.
      DOM
      • Paul J.
        • September 9, 2008
        • 2091
        ALWAYS wear safety glasses and/or a face shield when working near/on a battery.
        Spoken like a true shop teacher.
        • Gary J.
          • April 1, 1980
          • 1244
          I would think that on a battery there would be a warning label to wear saftey goggles and a face shield.
            • 15608
            I think there is, but as usual we have to read it and put it into action.
            • Larry E.
              • 1690
              Originally posted by Larry Evoskis (16324)
              Have a older car that uses a side terminal battery. I always unplug one side of the battery when car is not used or at
              a car show. The terminal (plus side) of the battery has broken on me. When I try to put the battery cable on it the inside
              of the terminal spins and can not get the cable tight. Is there anyway of fixing this? Perhaps drilling a small hole and
              inserting a screw as to use it as a "pin"? Would this work or does anybody have other ideas? If not I guess the battery is a throw away item now. No I do not have a battery
              switch; perhaps I will get one now. Thanks in advance; Larry
              Final Conclustion; Problem Solved:
              I should have done this first but I didn't and assumed something else. ====I took the bolt out of the cable and put it under a bright light and it
              was stripped ever so slighty. I had a extra set of cables so I took out the exact same type bolt and put it on the cable in the car. It snugged up fine. I guess in
              this case the battery insert was tougher then the bolt. (Maybe the insert are stainless steel as indicated by Terry) Thanks to all.--Larry
              P.S. Joe Lucia was correct but it was the bolt not the insert.
              Larry
              LT1 in a 1LE -- One of 134
                • 15608
                Larry,
                I am glad you solved your problem, and so easily too. New bolts with the smaller (5/16-inch) hex head are commonally available at your FLAPS in the HELP bubble packs. If you want the larger (7/16-inch) hex head, those would be harder to come by. There is an Adapter Kit that used to be commonly available with the larger hex size bolts and clamp-on connecters to turn top terminal cables into side terminal cables, but I haven't seen them in years. If you have an interest in those I can get you the GM part number when I return home. I haven't looked on evil bay, but that might be an option.
