'68 wheel color - NCRS Discussion Boards
'68 wheel color
  • Brian W.
    • September 30, 1990
    • 216
    '68 wheel color
    Judging manual states silver with a pale greenish hue, is this argent silver or better still, does anyone have a paint code I can use? Thanks
  • Jim T.
    • March 1, 1993
    • 5351
    Re: '68 wheel color
    If your 68's spare tire is original and even has the original tire from the factory the color of the wheel should be able to give you information.
    • Brian W.
      • 216
      Re: '68 wheel color
      Spare was repainted also.
      • Terry B.
        • August 31, 1999
        • 607
        Re: '68 wheel color
        The Argent Silver color seems to be subjective for some judges. I've heard on my rims, too much silver or too much green. As Jim says, look for an original spare but that may be hard to find. I was able to find an original '70 spare tire and brought it to a paint supplier and he matched the color the best he could but it still lost points. The latest judging on my car said the rims were too shiney. Sorry I do not have the formula but you probably could do better anyway. You might want to try the paint that Corvette Central or Paragon sells. Just be prepared for a few points (1 or 2) taken off. Maybe someone else will have a better way to match the color.
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
        • Gene M.
          • April 1, 1985
          • 4233
          Re: '68 wheel color
          Brian,
          It is my experience the EARLY 68 wheel color is the same as 67. My original 68 spare wheel compared to my 67 original spare wheel look the same color. Just argent silver no green hue at all that I can see. The finish (both 67 & 68) is dull, flat not shine at all. Now GM may have changed the color mix later in the build, I can't say.
          • Paul O.
            • August 31, 1990
            • 1716
            Re: '68 wheel color
            Here are some photos of a spare rim and tire as you can see has a very low luster. They are of a 1972 straight silver color no green hue.
