Re: PV cold fast idle speed 66 327/300hp
The two things that come to mind are the choke vacuum break adjustment and probably the main reason the chokes don't fully close even with outside air temps warm is proper choke coil adjustment. If the choke coil does not fully close the blade the highest idle on the step will not set. After start up when the vacuum break pulls the choke open slightly if you tap the acellerator pedal the high idle will set at the next lower step, that's why Bill stated to not touch the pedal.
Making someone use dry ice to check something like that is just not right IMO..
