Smog Pump Pulley Spacer - NCRS Discussion Boards
  • Peter S.
    • March 28, 2012
    • 327
    I have a smog pump pulley spacer that is too deep for my '69 L46. The spacer measures 1 3/4" in diameter, but is 3/4" deep. Did the early C3s have different depth spacers, or did depths vary depending on the engine? This was advertised as a '68-'72 smog pump pulley spacer when I purchased it.
    • 43219
    Re: Smog Pump Pulley Spacer
    Peter-----
    There were several different spacers used depending upon application and some applications used no spacer. The one for your application was 21/32" thick. All original spacers for 1969 were machined steel and not aluminum.
    • Peter S.
      • March 28, 2012
      • 327
      Joe,
      Do you know what application used a 3/4" thick spacer?
      • Kenneth H.
        • October 27, 2008
        • 500
        Joe, as always, you have the answer. I was wondering about the smog pump spacer for my 1970 LT1. Do you happen to know the correct spacer thickness for that application?
        Thanks.
          • 43219
          Joe,
          Peter------
          As far as 68-72 Corvettes go, the 3/4" spacer was used for the following:
          1968 with L-79
          1971-72 LT-1
            • 43219
            Thanks.
            Ken------
            21/32"
            • Kenneth H.
              • October 27, 2008
              • 500
              Joe,
              Thanks for the info.
              • Peter S.
                • March 28, 2012
                • 327
                Thanks for the info Joe!
                Peter
